Saltar al contenido principal
iLive IKBC384S Power cord and connector Replacement
Qué necesitas
  1. iLive IKBC384S Power cord and connector Replacement, Top Cover: paso 1, imagen 1 de 2 iLive IKBC384S Power cord and connector Replacement, Top Cover: paso 1, imagen 2 de 2
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S Power cord and connector Replacement: paso 2, imagen 1 de 2 iLive IKBC384S Power cord and connector Replacement: paso 2, imagen 2 de 2
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S Power cord and connector Replacement: paso 3, imagen 1 de 2 iLive IKBC384S Power cord and connector Replacement: paso 3, imagen 2 de 2
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S Power cord and connector Replacement, Power cord and AC connector: paso 4, imagen 1 de 1
    • Remove the one (13.5mm in length) srew holding the power connector and cord in place.
  5. iLive IKBC384S Power cord and connector Replacement: paso 5, imagen 1 de 1
    • Remove the power cord connected to the motherboard.
Conclusión
Allen Dover
Miembro Desde 03/21/17
401 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 313
