Saltar al contenido principal
iLive IKBC384S Motherboard Replacement
Qué necesitas
  1. iLive IKBC384S Motherboard Replacement, Top Cover: paso 1, imagen 1 de 2 iLive IKBC384S Motherboard Replacement, Top Cover: paso 1, imagen 2 de 2
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S Motherboard Replacement: paso 2, imagen 1 de 2 iLive IKBC384S Motherboard Replacement: paso 2, imagen 2 de 2
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S Motherboard Replacement: paso 3, imagen 1 de 2 iLive IKBC384S Motherboard Replacement: paso 3, imagen 2 de 2
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S Motherboard Replacement, Motherboard: paso 4, imagen 1 de 1
    • After removing the top of the device, locate the screws on the motherboard. Gently unscrew all four of the 3.5mm screws on the motherboard.
  5. iLive IKBC384S Motherboard Replacement: paso 5, imagen 1 de 2 iLive IKBC384S Motherboard Replacement: paso 5, imagen 2 de 2
    • Unplug the ribbon cable connected to the motherboard that stems from the disc drive.
    • Disconnect the two power connectors from the motherboard.
  6. iLive IKBC384S Motherboard Replacement: paso 6, imagen 1 de 1
    • You will need to desolder the antenna.
    • Be sure to desolder the piece connected to the motherboard not the wire.
  7. iLive IKBC384S Motherboard Replacement: paso 7, imagen 1 de 1
    • You will need to remove the speakers and power connector.
    • Once you have removed all of these from the motherboard, the motherboard can be removed
Conclusión
Tracy Walts
Miembro Desde 03/21/17
201 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 274
