Introducción
You will be replacing the entire disk drive in your radio, the only special tool that is needed for this replacement are the iOpener or heat gun because of the adhesive.
Qué necesitas
Make sure you remove all seven 3 mm screws before proceeding to the next step.
Casi Terminas!
Conclusión
