Saltar al contenido principal
iLive IKBC384S Disk Drive Replacement
Qué necesitas
  1. iLive IKBC384S Disk Drive Replacement, Top Cover: paso 1, imagen 1 de 2 iLive IKBC384S Disk Drive Replacement, Top Cover: paso 1, imagen 2 de 2
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S Disk Drive Replacement: paso 2, imagen 1 de 2 iLive IKBC384S Disk Drive Replacement: paso 2, imagen 2 de 2
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S Disk Drive Replacement: paso 3, imagen 1 de 2 iLive IKBC384S Disk Drive Replacement: paso 3, imagen 2 de 2
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S Disk Drive Replacement, Disk Drive: paso 4, imagen 1 de 2 iLive IKBC384S Disk Drive Replacement, Disk Drive: paso 4, imagen 2 de 2
    • Remove all four screws(13.5 mm in length) that are securing the device
  5. iLive IKBC384S Disk Drive Replacement: paso 5, imagen 1 de 2 iLive IKBC384S Disk Drive Replacement: paso 5, imagen 2 de 2
    • Remove both of the connected cords on the motherboard.
    • Also remove the flat ribbon cable that is connected to the motherboard.
    • Once you have removed all screws and cables connected to motherboard the disk drive can be easily removed
Conclusión
Allen Dover
Miembro Desde 03/21/17
401 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 412
