Saltar al contenido principal
iLive IKBC384S FM/AM Antenna Replacement
Qué necesitas
  1. iLive IKBC384S  FM/AM Antenna Replacement, Top Cover: paso 1, imagen 1 de 2 iLive IKBC384S  FM/AM Antenna Replacement, Top Cover: paso 1, imagen 2 de 2
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S  FM/AM Antenna Replacement: paso 2, imagen 1 de 2 iLive IKBC384S  FM/AM Antenna Replacement: paso 2, imagen 2 de 2
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S  FM/AM Antenna Replacement: paso 3, imagen 1 de 2 iLive IKBC384S  FM/AM Antenna Replacement: paso 3, imagen 2 de 2
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S  FM/AM Antenna Replacement, FM/AM Antenna: paso 4, imagen 1 de 2 iLive IKBC384S  FM/AM Antenna Replacement, FM/AM Antenna: paso 4, imagen 2 de 2
    • Remove all four screws(13.5 mm in length) that are securing the disk drive.
  5. iLive IKBC384S  FM/AM Antenna Replacement: paso 5, imagen 1 de 2 iLive IKBC384S  FM/AM Antenna Replacement: paso 5, imagen 2 de 2
    • Unplug the ribbon cable connected to the motherboard that stems from the disc drive.
    • Also, disconnect the two power connectors from the motherboard.
    • Once you have removed the ribbon cables and two connectors on the motherboard the disk drive can be removed.
  6. iLive IKBC384S  FM/AM Antenna Replacement: paso 6, imagen 1 de 1
    • After removing the top of the device, locate the screws on the motherboard. Gently unscrew all four of the 3.5mm screws on the motherboard.
  7. iLive IKBC384S  FM/AM Antenna Replacement: paso 7, imagen 1 de 2 iLive IKBC384S  FM/AM Antenna Replacement: paso 7, imagen 2 de 2
    • Desolder the antenna at the contact point.
    • Check out this awesome guide for soldering and desoldering tips.
  8. iLive IKBC384S  FM/AM Antenna Replacement: paso 8, imagen 1 de 2 iLive IKBC384S  FM/AM Antenna Replacement: paso 8, imagen 2 de 2
    • Place iOpener on antenna for approximately 5 minutes
  9. iLive IKBC384S  FM/AM Antenna Replacement: paso 9, imagen 1 de 1
    • Lift up and remove all of the antenna.
    • The antenna will be glued down all the way around the radio
Conclusión
Tracy Walts
Miembro Desde 03/21/17
201 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 686
