Saltar al contenido principal
iHome iW1 Battery Replacement
Qué necesitas
  1. iHome iW1 Battery Replacement, Battery: paso 1, imagen 1 de 3 iHome iW1 Battery Replacement, Battery: paso 1, imagen 2 de 3 iHome iW1 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Remove the rubber from the bottom of the speaker, use a medium blue plastic spudger to gently work its way under the rubber and slowly peel off for each of the three feet. The order does not matter.
  2. iHome iW1 Battery Replacement: paso 2, imagen 1 de 2 iHome iW1 Battery Replacement: paso 2, imagen 2 de 2
    • Remove the six 11 mm Philips #1 screws found underneath the foam to remove the steel outer metal frame.
    • Once the screws come off, keep them safely off to the side.
  3. iHome iW1 Battery Replacement: paso 3, imagen 1 de 2 iHome iW1 Battery Replacement: paso 3, imagen 2 de 2
    • Remove the metal frame gently and set aside.
  4. iHome iW1 Battery Replacement: paso 4, imagen 1 de 2 iHome iW1 Battery Replacement: paso 4, imagen 2 de 2
    • Remove the two remaining 11 mm Philips #1 screws holding the base and set them aside.
  5. iHome iW1 Battery Replacement: paso 5, imagen 1 de 3 iHome iW1 Battery Replacement: paso 5, imagen 2 de 3 iHome iW1 Battery Replacement: paso 5, imagen 3 de 3
    • Lift the base up gently keeping in mind that the base is connected with wires to internal parts of the speaker.
    • Disconnect the white bundled cable connector attached to the charging node using a spudger. The base of the speaker is now free to be removed.
  6. iHome iW1 Battery Replacement: paso 6, imagen 1 de 3 iHome iW1 Battery Replacement: paso 6, imagen 2 de 3 iHome iW1 Battery Replacement: paso 6, imagen 3 de 3
    • Remove the white power cable connector that connects the charging node to the battery, using the plastic spudger.
    • Pry the battery off using the plastic spudger.
Conclusión
2 personas más completaron esta guía.
Salma Mohamed
Miembro Desde 02/14/17
137 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 20-6, Remmell Spring 2017 Miembro de USF Tampa, Team 20-6, Remmell Spring 2017
USFT-REMMELL-S17S20G6
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 17
Todo El Tiempo: 2,944
