Introducción
This guide instructs you to replace the buttons in an iHome iPL8. The process includes using two sizes of screwdrivers.
Qué necesitas
Turn the device over to access the bottom panel.
Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
Keeping your device upside-down, locate the four 6mm Phillips #2 screws near each corner.
Remove the four 6mm Phillips #2 screws.
Locate the green circuit board. This panel is clipped onto two black, circular-shaped columns at two corners.
Pull out the green circuit board on the two corners.
The green circuit board is attached to a black box at the bottom. Flip the panel and the black box together to open the device.
Locate the light brown, rectangular button board. Remove the five 2.5 mm Phillips #1 screws, four along the perimeter and one in the center.
Remove the brown button board.
There is a foam sheet underneath the button board. Use your hand to take it off and put it aside.
Una persona más ha completado esta guía.
