Saltar al contenido principal
iHome iP21 Speaker Replacement
Qué necesitas
  1. iHome iP21 Speaker Replacement, Base: paso 1, imagen 1 de 3 iHome iP21 Speaker Replacement, Base: paso 1, imagen 2 de 3 iHome iP21 Speaker Replacement, Base: paso 1, imagen 3 de 3
    • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
    • Unscrew the four 11mm screws from the base.
    • Pry the base loose using the spudger.
    • Remove the base by hand.
  2. iHome iP21 Speaker Replacement, Housing: paso 2, imagen 1 de 2 iHome iP21 Speaker Replacement, Housing: paso 2, imagen 2 de 2
    • Remove the two black 6mm screws connecting the main circuit board to the housing top.
    • Gently pull front housing from the back housing.
  3. iHome iP21 Speaker Replacement, Remove Speaker Assembly: paso 3, imagen 1 de 1
    • Remove two 9mm screws holding speaker assembly in iP21, using iFixit Phillips #2 bit
  4. iHome iP21 Speaker Replacement, Remove speaker from speaker assembly: paso 4, imagen 1 de 2 iHome iP21 Speaker Replacement, Remove speaker from speaker assembly: paso 4, imagen 2 de 2
    • Lift speaker assembly
    • Remove four 7mm screws to detach speaker from speaker assembly
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 203
