Qué necesitas
Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
Unscrew the four 11mm screws from the base.
Pry the base loose using the spudger.
Remove the base by hand.
Remove the two black 6mm screws connecting the main circuit board to the housing top.
Gently pull front housing from the back housing.
Remove two 9mm screws holding speaker assembly in iP21, using iFixit Phillips #2 bit
Lift speaker assembly
Remove four 7mm screws to detach speaker from speaker assembly
