Saltar al contenido principal
iHome iP21 Docking Station Pin Replacement
Qué necesitas
  1. iHome iP21 Docking Station Pin Replacement, Base: paso 1, imagen 1 de 3 iHome iP21 Docking Station Pin Replacement, Base: paso 1, imagen 2 de 3 iHome iP21 Docking Station Pin Replacement, Base: paso 1, imagen 3 de 3
    • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
    • Unscrew the four 11mm screws from the base.
    • Pry the base loose using the spudger.
    • Remove the base by hand.
  2. iHome iP21 Docking Station Pin Replacement, Housing: paso 2, imagen 1 de 2 iHome iP21 Docking Station Pin Replacement, Housing: paso 2, imagen 2 de 2
    • Remove the two black 6mm screws connecting the main circuit board to the housing top.
    • Gently pull front housing from the back housing.
  3. iHome iP21 Docking Station Pin Replacement, 30-pin docking mount: paso 3, imagen 1 de 1
    • Locate the 30-pin docking mount on the iP21. The 30-pin docking mount is visible on top of the iP21.
  4. iHome iP21 Docking Station Pin Replacement, Protective cover: paso 4, imagen 1 de 2 iHome iP21 Docking Station Pin Replacement, Protective cover: paso 4, imagen 2 de 2
    • Remove the four 4mm screws from the protective cover using the iFixit Phillips #1 bit
  5. iHome iP21 Docking Station Pin Replacement, Ribbon cables: paso 5, imagen 1 de 3 iHome iP21 Docking Station Pin Replacement, Ribbon cables: paso 5, imagen 2 de 3 iHome iP21 Docking Station Pin Replacement, Ribbon cables: paso 5, imagen 3 de 3
    • Grasp plastic cable connector ends
    • Remove the mini circuit board with 30-pin mounting dock from the two black plastic pegs.
    • Rock gently back and forth and pull to detach mini circuit board with 30-pin mounting dock attached.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 12
Todo El Tiempo: 723
