Saltar al contenido principal
iHome iH5 Charging Dock Replacement
Qué necesitas
  1. iHome iH5 Charging Dock Replacement, Charging Dock: paso 1, imagen 1 de 1
    • Remove the eight 5/16 inch screws with a #2 Phillips screwdriver.
  2. iHome iH5 Charging Dock Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to unplug the three wires connected to the circuit board. If the wires are tight pliers might work better.
  3. iHome iH5 Charging Dock Replacement: paso 3, imagen 1 de 1
    • Remove the five 5/16 inch screws from the circuit board.
  4. iHome iH5 Charging Dock Replacement: paso 4, imagen 1 de 2 iHome iH5 Charging Dock Replacement: paso 4, imagen 2 de 2
    • Flip the circuit board over.
    • There are capacitors all over the back side of the board. Be careful not to touch these capacitors (blue cylinders) as they can discharge—giving you a shock.
    • Unplug the eight wires attached to the circuit board with tweezers. If the wires are tight pliers might work better.
    • There is on wire in the orange box.
    • There are two wires in the yellow box.
    • There are five wires in the green box.
  5. iHome iH5 Charging Dock Replacement: paso 5, imagen 1 de 1
    • Remove the following four screws securing the iHome iH5 charging dock.
    • Use a #2 Phillips screwdriver to remove the four screws.
  6. iHome iH5 Charging Dock Replacement: paso 6, imagen 1 de 1
    • Gently remove the charging dock from the iHome iH5 by pulling it up.
  7. iHome iH5 Charging Dock Replacement: paso 7, imagen 1 de 1
    • Remove the final screws connecting the iH5 charging dock to the plastic holding platform
    • Use a #2 Phillips screwdriver to remove the 3/8 inch screws.
  8. iHome iH5 Charging Dock Replacement: paso 8, imagen 1 de 1
    • Replace the old iH5 charging dock with new iH5 charging dock.
Conclusión
Dustin Lamb
Miembro Desde 03/13/14
103 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 968
