Saltar al contenido principal
iHome iH3L Batteries Replacement
Qué necesitas
  1. iHome iH3L Batteries Replacement, Batteries: paso 1, imagen 1 de 2 iHome iH3L Batteries Replacement, Batteries: paso 1, imagen 2 de 2
    • Using your finger, pry the tab on the battery cover to remove the battery cover on the back of the iHome to access the batteries.
  2. iHome iH3L Batteries Replacement: paso 2, imagen 1 de 3 iHome iH3L Batteries Replacement: paso 2, imagen 2 de 3 iHome iH3L Batteries Replacement: paso 2, imagen 3 de 3
    • With the battery panel off, remove the batteries. Use your hands or a plastic spudger to remove the batteries.
  3. iHome iH3L Batteries Replacement: paso 3, imagen 1 de 2 iHome iH3L Batteries Replacement: paso 3, imagen 2 de 2
    • When removing the batteries make sure to remove corrosion. Wear gloves when removing corrosion and use proper disposal.
    • Make sure to avoid contact with your eyes or mouth as it can cause irritation and lead to other problems.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 205
