Saltar al contenido principal
Introducción
You will be removing screws and pulling out your broken adapter in order to replace it with a new adapter.
  1. iHome iH27B iPod Adapter Replacement, iPod Adapter: paso 1, imagen 1 de 1
    • Set the device with the adapter facing up.
    • Remove the following screws:
    • Two 10 mm Phillips #0
  2. iHome iH27B iPod Adapter Replacement: paso 2, imagen 1 de 1
    • Grip the plastic adapter case and pull upwards with a medium amount of force. You will have to twist forward a little so that the connections are visible.
    • The adapter will still be connected with wires, so make sure not to pull too hard.
  3. iHome iH27B iPod Adapter Replacement: paso 3, imagen 1 de 3 iHome iH27B iPod Adapter Replacement: paso 3, imagen 2 de 3 iHome iH27B iPod Adapter Replacement: paso 3, imagen 3 de 3
    • Four 7 mm Phillips #0
    • Lift out the two black plastic pieces that have come loose on either side of the circuit board, and set them aside.
  4. iHome iH27B iPod Adapter Replacement: paso 4, imagen 1 de 2 iHome iH27B iPod Adapter Replacement: paso 4, imagen 2 de 2
    • Carefully pry apart the bundle of white wires connected at the junction with the plastic opening tool.
    • Do this slowly. Be careful not to damage the wires
    • Lift out the circuit board that has become loose.
  5. iHome iH27B iPod Adapter Replacement: paso 5, imagen 1 de 1
    • Pull out the adapter, and replace it with the new one.
Conclusión
John Kraemer
Miembro Desde 09/10/12
64 Reputación
9 Guías creadas
Equipo
Cal Poly, Team 3-21, Amido Fall 2012 Miembro de Cal Poly, Team 3-21, Amido Fall 2012
CPSU-AMIDO-F12S3G21
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 2,230
