Saltar al contenido principal
iHome iH27B Main Motherboard Replacement
Qué necesitas
  1. iHome iH27B Main Motherboard Replacement, Outer Case: paso 1, imagen 1 de 1
    • Remove any iPod or apple music device connected to the iHome and unplug from any power source.
    • Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
  2. iHome iH27B Main Motherboard Replacement: paso 2, imagen 1 de 3 iHome iH27B Main Motherboard Replacement: paso 2, imagen 2 de 3 iHome iH27B Main Motherboard Replacement: paso 2, imagen 3 de 3
    • Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
    • Remove the plastic slide from its location and set it aside.
    • These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
    • Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
    • Set the batteries aside, careful to not get them wet.
    • Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
    • Apply force in the direction of the arrow shown above the word "Open" on the plastic. The plastic piece covering the watch battery should come loose.
    • Set this plastic covering aside as well.
  3. iHome iH27B Main Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove the following screws:
    • Eight 10 mm Phillips #0
    • Cataloging each screw by size in plastic bags or separate places on a flat surface will make them easier to find when reassembling.
  4. iHome iH27B Main Motherboard Replacement: paso 4, imagen 1 de 1
    • Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
    • Be careful not to pry too hard. Cracking the plastic connections could make reassembly harder.
  5. iHome iH27B Main Motherboard Replacement: paso 5, imagen 1 de 1
    • Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
    • You should have visible access to most of the components inside the iHome now.
  6. iHome iH27B Main Motherboard Replacement, AV circuit board: paso 6, imagen 1 de 1
    • Two 10 mm Phillips #0
  7. iHome iH27B Main Motherboard Replacement: paso 7, imagen 1 de 1
    • Pull out the AV circuit board and lift it up and out of the way to allow access to other components.
  8. iHome iH27B Main Motherboard Replacement, Main Motherboard: paso 8, imagen 1 de 1
    • Pull the speakers away and set them aside for now. They should still be connected to the rest of the iHome by two wires.
  9. iHome iH27B Main Motherboard Replacement: paso 9, imagen 1 de 1
    • Remove the following 6 screws:
    • Two 7 mm Phillips #0
    • Three 10 mm Phillips #2
    • One 9 mm Phillips #2
    • Set the screws aside, careful to not mix them up with your other screws.
Conclusión
John Kraemer
Miembro Desde 10/09/12
64 Reputación
9 Guías creadas
Equipo
Cal Poly, Team 3-21, Amido Fall 2012 Miembro de Cal Poly, Team 3-21, Amido Fall 2012
CPSU-AMIDO-F12S3G21
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 815
