Saltar al contenido principal
iHome iD95 Bottom Cover Replacement
Qué necesitas
  1. iHome iD95 Bottom Cover Replacement, Backup Battery: paso 1, imagen 1 de 1
    • Before taking apart the iD95, disconnect the AC cord from the wall socket and AC adapter from the DC jack. Remove any iPods, iPhones, and iPads attached to the device.
    • Flip over the iD95 so the bottom cover is visible and the LCD screen is facing you.
  2. iHome iD95 Bottom Cover Replacement: paso 2, imagen 1 de 1
    • Remove the 10 mm-length, 5 mm-head screw using a Phillips #1 screwdriver.
  3. iHome iD95 Bottom Cover Replacement: paso 3, imagen 1 de 1
    • Use a plastic opening tool to take out the backup battery.
  4. iHome iD95 Bottom Cover Replacement, Bottom Cover: paso 4, imagen 1 de 1
    • Unscrew five 17 mm-length, 6 mm-head screws using a Phillips #1 screwdriver.
  5. iHome iD95 Bottom Cover Replacement: paso 5, imagen 1 de 2 iHome iD95 Bottom Cover Replacement: paso 5, imagen 2 de 2
    • The bottom cover is attached to the back cover by two plastic clips. Don't use excessive force.
    • Insert a plastic opening tool between the edge of the bottom cover and the main body.
    • Gently pry the bottom cover from the body. Start anywhere along the front side of the iD95 and work your way around.
    • Grip the bottom portion of the device and gently lift the front part of the bottom cover a couple centimeters up.
  6. iHome iD95 Bottom Cover Replacement: paso 6, imagen 1 de 2 iHome iD95 Bottom Cover Replacement: paso 6, imagen 2 de 2
    • Potential for device damage: Be careful not to use too much force or you might break the plastic rings holding the side panels in place.
    • Lift up the bottom cover. Pull the side panel up first, out, and away from the device.
    • The side panels have plastic rings that will need to be lifted up and off the cylinders they are placed around.
  7. iHome iD95 Bottom Cover Replacement: paso 7, imagen 1 de 2 iHome iD95 Bottom Cover Replacement: paso 7, imagen 2 de 2
    • Apply the same techniques from the previous step to remove the remaining side panel.
  8. iHome iD95 Bottom Cover Replacement: paso 8, imagen 1 de 3 iHome iD95 Bottom Cover Replacement: paso 8, imagen 2 de 3 iHome iD95 Bottom Cover Replacement: paso 8, imagen 3 de 3
    • Locate the two plastic clips holding the bottom and back cover together.
    • Which clip you remove first is up to you. Rotate the device 90 degrees either left or right. Insert the flat end of a spudger horizontally between the back speaker and the back cover.
    • Place the flat end of the spudger behind one clip and pry it open. This may take repeated attempts.
    • This is the hardest step because the angle is awkward and the visibility is poor. If possible, have someone hold the device or provide lighting.
    • Once a clip has been removed, hold the bottom cover open so the clip will not fall back into place. One clip remains to be removed; you are almost there!
  9. iHome iD95 Bottom Cover Replacement: paso 9, imagen 1 de 2 iHome iD95 Bottom Cover Replacement: paso 9, imagen 2 de 2
    • Use the same steps to remove the remaining clip.
    • The bottom cover is still connected to the motherboard by wiring.
  10. iHome iD95 Bottom Cover Replacement: paso 10, imagen 1 de 2 iHome iD95 Bottom Cover Replacement: paso 10, imagen 2 de 2
    • Use a plastic opening tool to pry off the white ZIF connector joining the wires to the motherboard.
    • Don't pull the wires. Take your time using a plastic opening tool.
Conclusión
Vincent Chan
Miembro Desde 04/18/13
19 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 12-37, Amido Spring 2013 Miembro de Cal Poly, Team 12-37, Amido Spring 2013
CPSU-AMIDO-S13S12G37
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 644
