Saltar al contenido principal
iHome iAVS16 Power Board Replacement
Qué necesitas
  1. iHome iAVS16 Power Board Replacement, Power Board: paso 1, imagen 1 de 3 iHome iAVS16 Power Board Replacement, Power Board: paso 1, imagen 2 de 3 iHome iAVS16 Power Board Replacement, Power Board: paso 1, imagen 3 de 3
    • Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
    • Lift up the bottom of the device.
    • Carefully lift the bottom of the device up as to not damage the ribbon cable connecting it.
  2. iHome iAVS16 Power Board Replacement: paso 2, imagen 1 de 3 iHome iAVS16 Power Board Replacement: paso 2, imagen 2 de 3 iHome iAVS16 Power Board Replacement: paso 2, imagen 3 de 3
    • Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
    • Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
    • Lifting too quickly could damage the ribbon cable still attached.
  3. iHome iAVS16 Power Board Replacement: paso 3, imagen 1 de 2 iHome iAVS16 Power Board Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using the tweezers, lift up on the black tab holding the ribbon cable down.
    • Carefully pull the ribbon cable back and out of the slot.
  4. iHome iAVS16 Power Board Replacement: paso 4, imagen 1 de 3 iHome iAVS16 Power Board Replacement: paso 4, imagen 2 de 3 iHome iAVS16 Power Board Replacement: paso 4, imagen 3 de 3
    • Remove the two 1.7 mm Phillips #0 screws holding the power board in.
    • Carefully flip the board over.
    • Remove the red connector from its socket with a pair of tweezers.
Conclusión
Ashley Famularo
Miembro Desde 10/25/19
181 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 115
