Saltar al contenido principal
iHip Fold-up Portable Speaker Back Cover Removal
Qué necesitas
  1. iHip Fold-up Portable Speaker Back Cover Removal, Removing the battery case cover: paso 1, imagen 1 de 1
    • Use your fingers to slide the battery case cover off in the direction of the arrows.
  2. iHip Fold-up Portable Speaker Back Cover Removal, Cleaning the battery case: paso 2, imagen 1 de 3 iHip Fold-up Portable Speaker Back Cover Removal, Cleaning the battery case: paso 2, imagen 2 de 3 iHip Fold-up Portable Speaker Back Cover Removal, Cleaning the battery case: paso 2, imagen 3 de 3
    • Remove the four AAA batteries. Be sure to check your nearest battery recycling point!
    • Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
  3. iHip Fold-up Portable Speaker Back Cover Removal, Removing the screws: paso 3, imagen 1 de 2 iHip Fold-up Portable Speaker Back Cover Removal, Removing the screws: paso 3, imagen 2 de 2
    • Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
    • Screws will be magnetized in position and will require the use of tweezers to be removed.
    • Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
    • Unscrew the 0.6 mm screw located in the center of the battery case.
    • Keep the 1.0 mm and 0.6 mm screws separate from each other for reassembly.
  4. iHip Fold-up Portable Speaker Back Cover Removal, Removing the back cover: paso 4, imagen 1 de 2 iHip Fold-up Portable Speaker Back Cover Removal, Removing the back cover: paso 4, imagen 2 de 2
    • Remove the back cover carefully; there are many wires that connect it to the device.
Conclusión
Cristina Garcia
Miembro Desde 10/13/14
301 Reputación
3 Guías creadas
Equipo
Clemson, Team 3-4, Benson Fall 2014 Miembro de Clemson, Team 3-4, Benson Fall 2014
CLEM-BENSON-F14S3G4
5 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 276
