Saltar al contenido principal
iFixit 26 Bit Driver Kit Technique for Removing Bits
Qué necesitas
  1. iFixit 26 Bit Driver Kit Technique for Removing Bits, iFixit 26 Bit Driver Kit Technique for Removing Bits: paso 1, imagen 1 de 1
    • Note how challenging it is to remove a required bit from the kit. Argh!
  2. iFixit 26 Bit Driver Kit Technique for Removing Bits: paso 2, imagen 1 de 1
    • Find yourself a rubber band...
  3. iFixit 26 Bit Driver Kit Technique for Removing Bits: paso 3, imagen 1 de 1
    • Wrap said band around the bit and viola! easy bit extraction enabled. You might want to keep that handy rubber band with the kit now.
  4. iFixit 26 Bit Driver Kit Technique for Removing Bits: paso 4, imagen 1 de 1
    • Alternate, no-rubber-band solution: use the tweezers supplied in the bit driver kit.
Conclusión
48 personas más completaron esta guía.
aaronmiller
Miembro Desde 08/28/11
1,376 Reputación
1 Guía escrita
Un comentario
I want to order the 26 bit driver kit technique for removing bits
clement mEnThChEl - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 39
Todo El Tiempo: 4,690
