Saltar al contenido principal
iDevices iGrill Probe Replacement
Qué necesitas
  1. iDevices iGrill Probe Replacement, Probes: paso 1, imagen 1 de 1
    • Remove the back plastic cover from the device; this should allow you access to the batteries.
  2. iDevices iGrill Probe Replacement: paso 2, imagen 1 de 1
    • Remove the batteries from the device.
  3. iDevices iGrill Probe Replacement: paso 3, imagen 1 de 2 iDevices iGrill Probe Replacement: paso 3, imagen 2 de 2
    • Remove five black 10 mm Phillips #0 screws from the back side of the device.
    • Remove two silver-colored 5 mm screws using a Phillips screwdriver. The screws are located on the left side of the internal cover.
    • Remove the accompanying plastic tabs under the screws.
    • Gently pull off the back cover from the device.
  4. iDevices iGrill Probe Replacement: paso 4, imagen 1 de 3 iDevices iGrill Probe Replacement: paso 4, imagen 2 de 3 iDevices iGrill Probe Replacement: paso 4, imagen 3 de 3
    • If you have not removed the 2 silver-colored screws; you must remove them now.
    • Remove the metal terminals from the battery slot closest you.
    • Pull the remaining metal terminals out of their slots. Position them such that when removing the internal cover they will not be caught.
    • Remove the internal cover.
  5. iDevices iGrill Probe Replacement: paso 5, imagen 1 de 1
    • After the internal plastic case has been removed, you will have access to the probe contacts.
    • You should then insert the probes to check their connection to the probe terminals.
  6. iDevices iGrill Probe Replacement: paso 6, imagen 1 de 1
    • Using a pair of tweezers, bend the probe contacts back in place. The tweezers will touch the probe terminals when inserted.
Conclusión
Michelle Nguyen
Miembro Desde 02/16/16
204 Reputación
2 Guías creadas
Equipo
IUPUI, Team 3-4, Harley Spring 2016 Miembro de IUPUI, Team 3-4, Harley Spring 2016
IUPUI-HARLEY-S16S3G4
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,047
