Saltar al contenido principal
iDea USA CT702 Microphone Replacement
Qué necesitas
  1. iDea USA CT702 Microphone Replacement, Microphone: paso 1, imagen 1 de 1
    • Place the tablet face up with portholes facing you.
  2. iDea USA CT702 Microphone Replacement: paso 2, imagen 1 de 2 iDea USA CT702 Microphone Replacement: paso 2, imagen 2 de 2
    • Use a fingernail, or a plastic opening tool to gently pry the black panel around the portholes.
    • Be gentle and take your time. Excessive force could damage the device.
  3. iDea USA CT702 Microphone Replacement: paso 3, imagen 1 de 3 iDea USA CT702 Microphone Replacement: paso 3, imagen 2 de 3 iDea USA CT702 Microphone Replacement: paso 3, imagen 3 de 3
    • Use your fingers to pry the rest of the back off; slowly apply pressure from each side to break each clip connection.
  4. iDea USA CT702 Microphone Replacement: paso 4, imagen 1 de 1
    • Once the back is off, position the tablet as shown and be sure to warm your soldering iron.
  5. iDea USA CT702 Microphone Replacement: paso 5, imagen 1 de 1
    • Place tip of the soldering iron on the end of the wire to break connection.
    • Remember to use proper safety precautions when soldering.
  6. iDea USA CT702 Microphone Replacement: paso 6, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Grip the new microphone with tweezers and place in the slot.
    • Solder the new connections while using tweezers to hold the speaker steady.
Conclusión
Benton Gray
Miembro Desde 03/11/15
201 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 118
