Introducción
Guide specifically for 1.33 GHz models. Replacing a defective fan is pretty easy and will keep your laptop running cool.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
  • Use a coin to rotate the battery locking screw 90 degrees clockwise.
Agregar Comentario
Lift the battery out of the computer.
  • Lift the battery out of the computer.
Agregar Comentario
  • Use a pin (or anything you like) to remove the three rubber feet from the lower case.
Agregar Comentario
  • Remove the three newly-revealed Phillips screws.
Agregar Comentario
  • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
Agregar Comentario
  • Remove the three hex screws using a T8 Torx screwdriver (or Allen screws using an Allen key if these are used).
  • The shorter screw is in the center of the computer.
Why use a T8 Torx when these screws are metric hex 2? The T8 didn't work at all. Other than that this was a very easy repair. It cost $29 instead of the $150 that I paid the last time a Mac shop made the same repair.
dalekaty - Contestar
Quote from dalekaty:
Had the same issue with a T8, although I blamed that on my T8 being quite stripped. Finding an appropriate bit was quite a challenge... but I'm pretty certain a T8 isn't correct. The screws have a hex head, not a Torx... maybe T8 is the closest thing that tends to fit...
Matt Falcon - Contestar
The screw on the left wasnt able to get tight for some reason
Helena - Contestar
Not Torx, but allen key (British wrench), 2mm
alicelittle - Contestar
I attempted this last night following all the steps correctly, when I was done my ibook would not turn on. Now sure where I went wrong? Any ideas. Thank you
stefanienikole - Contestar
  • Remove the two Phillips screws on either side of the battery contacts.
Agregar Comentario
  • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
  • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
I printed these instructions out, and this one was at the top of page 2. I found the first paragraph amusing enough that I had to show my boss.
Kristoffer Bisher - Contestar
  • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
  • Be careful not to break this clip!
Agregar Comentario
  • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
Agregar Comentario
  • Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
For me, this was really the toughest part! Trying to find/get a good grip on the iBook and really *forcing* that spudger around. All without scratching the display.
bccreative - Contestar
Once you loosen the the front the seam is very tight. I was able to slide the spudger in the middle of the port side instead of starting at the corner.
Robert Oliver - Contestar
  • There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
Agregar Comentario
  • Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free (it may be helpful to jiggle the case up and down).
This was the scariest part for me. I had to wiggle it a lot as it seemed to be stuck. But it did come loose.
  • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
Agregar Comentario
  • Remove the following 10 screws from the bottom shield:
    • Six 3 mm Phillips
    • Three 7.5 mm Phillips
    • One 14 mm Phillips
My 1 GHz iBook G4 only had the two 7.5 mm Phillips on the right and the two 3 mm Phillips above the battery compartment.
geekspeak - Contestar
  • Lift the bottom shield off.
The front of the foil cover has a lip divided into four separate tabs. Use a blade to loosen each as they can be easily bent.
My dc board had 2 screws. for some reason when i tried to screw them both back in only one got tight. the other one just kept twirling so i left it out. i didnt want to have a loose screw rattling around in my computer.
also had trouble laying down the wire to the dc board. it wouldnt lay flat but i was able to get it flat enough. overall it worked and the computer is now up and running!
thank you! it was pretty easy
Helena - Contestar
  • Remove the 4 Phillips screws securing the fan to the metal framework.
Agregar Comentario
  • Lift the fan out of its compartment and disconnect it from the logic board, removing tape as necessary.
How can you tell if your fan is bad? I'm replacing the hard drive and I figured I would change the fan too. It doesn't make any noise so I can never tell if it is working. Thanks
Conclusión
2 personas más completaron esta guía.
Documentos Adjuntos
iRobot
Miembro Desde 24/09/09
1 Reputación
621 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 5,095
