Saltar al contenido principal
Introducción
Internal Prerequisite.
Partes
No se especificaron partes.
  1. iBook G4 14" 1.42 GHz LCD Cover Replacement, LCD Cover: paso 1, imagen 1 de 2 iBook G4 14" 1.42 GHz LCD Cover Replacement, LCD Cover: paso 1, imagen 2 de 2
    • Remove the pieces of readily removable tape from around the perimeter of the display.
    • Carefully remove the aluminum tape covering the display data cable connection.
  2. iBook G4 14" 1.42 GHz LCD Cover Replacement: paso 2, imagen 1 de 2 iBook G4 14" 1.42 GHz LCD Cover Replacement: paso 2, imagen 2 de 2
    • Remove the single screw inserted through the piece of EMI tape near the bottom edge of the display.
    • Use the tip of a spudger to remove the small washer under the screw you just removed.
  3. iBook G4 14" 1.42 GHz LCD Cover Replacement: paso 3, imagen 1 de 1
    • Peel the aluminum/EMI tape off the cast aluminum frame of the clutch hinges.
    • It is not necessary to peel the tape off the thin steel LCD cover.
  4. iBook G4 14" 1.42 GHz LCD Cover Replacement: paso 4, imagen 1 de 2 iBook G4 14" 1.42 GHz LCD Cover Replacement: paso 4, imagen 2 de 2
    • Remove the two Phillips screws securing each side of the LCD to the clutch hinge frame (four screws total).
  5. iBook G4 14" 1.42 GHz LCD Cover Replacement: paso 5, imagen 1 de 1
    • Lift the thin steel LCD cover off the LCD.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 35
