Saltar al contenido principal
iBook G4 12" 1.33 GHz Rear Display Bezel Replacement
Qué necesitas
  1. iBook G4 12" 1.33 GHz Rear Display Bezel Replacement, Battery: paso 1, imagen 1 de 2 iBook G4 12" 1.33 GHz Rear Display Bezel Replacement, Battery: paso 1, imagen 2 de 2
    • Lay your iBook upside down on a flat surface.
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. iBook G4 12" 1.33 GHz Rear Display Bezel Replacement, Rear Display Bezel: paso 2, imagen 1 de 2 iBook G4 12" 1.33 GHz Rear Display Bezel Replacement, Rear Display Bezel: paso 2, imagen 2 de 2
    • Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
    • If you don't have a 1.5mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
  3. iBook G4 12" 1.33 GHz Rear Display Bezel Replacement: paso 3, imagen 1 de 2 iBook G4 12" 1.33 GHz Rear Display Bezel Replacement: paso 3, imagen 2 de 2
    • Insert the flat end of a spudger perpendicular to the face of the display into the gap between the front and rear bezels near the upper left corner of the display.
    • Rotate the spudger away from the display to pry the rear bezel off the front bezel.
  4. iBook G4 12" 1.33 GHz Rear Display Bezel Replacement: paso 4, imagen 1 de 1
    • Run your spudger along the top edge of the front display bezel to evenly separate the two bezels.
  5. iBook G4 12" 1.33 GHz Rear Display Bezel Replacement: paso 5, imagen 1 de 2 iBook G4 12" 1.33 GHz Rear Display Bezel Replacement: paso 5, imagen 2 de 2
    • Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display.
  6. iBook G4 12" 1.33 GHz Rear Display Bezel Replacement: paso 6, imagen 1 de 1
    • Use the flat end of a spudger to pry the rear bezel away from the right edge of the display.
    • If necessary, pry along the bottom edge of the rear bezel to separate it from the display assembly.
  7. iBook G4 12" 1.33 GHz Rear Display Bezel Replacement: paso 7, imagen 1 de 1
    • Lift the rear bezel off the display assembly.
Conclusión
3 personas más completaron esta guía.
Documentos Adjuntos
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 3,470
