Saltar al contenido principal
hp pavilion 15-cc023cl Motherboard Replacement
Qué necesitas
  1. hp pavilion 15-cc023cl Motherboard Replacement, Battery: paso 1, imagen 1 de 2 hp pavilion 15-cc023cl Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
  2. hp pavilion 15-cc023cl Motherboard Replacement: paso 2, imagen 1 de 1
    • Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Be gentle when applying force to the cover.
  3. hp pavilion 15-cc023cl Motherboard Replacement: paso 3, imagen 1 de 2 hp pavilion 15-cc023cl Motherboard Replacement: paso 3, imagen 2 de 2
    • Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
  4. hp pavilion 15-cc023cl Motherboard Replacement: paso 4, imagen 1 de 2 hp pavilion 15-cc023cl Motherboard Replacement: paso 4, imagen 2 de 2
    • Disconnect the port connecting the battery and the motherboard and then remove.
  5. hp pavilion 15-cc023cl Motherboard Replacement, Hard Drive: paso 5, imagen 1 de 1
    • Use a spudger to lift the latch that holds the hard drive cable in place.
  6. hp pavilion 15-cc023cl Motherboard Replacement: paso 6, imagen 1 de 1
    • Use a plastic opening tool to pry the hard drive out.
  7. hp pavilion 15-cc023cl Motherboard Replacement: paso 7, imagen 1 de 1
    • Disconnect the hard drive cable.
  8. hp pavilion 15-cc023cl Motherboard Replacement: paso 8, imagen 1 de 1
    • Lift the plastic wedges up on both sides of the hard drive.
  9. hp pavilion 15-cc023cl Motherboard Replacement, Motherboard: paso 9, imagen 1 de 1
    • Locate the motherboard.
  10. hp pavilion 15-cc023cl Motherboard Replacement: paso 10, imagen 1 de 2 hp pavilion 15-cc023cl Motherboard Replacement: paso 10, imagen 2 de 2
    • Use a PH0 screwdriver to unscrew the three 3 mm Phillips head screws located on the fan.
  11. hp pavilion 15-cc023cl Motherboard Replacement: paso 11, imagen 1 de 1
    • Use a PH1 screwdriver to unscrew the four 3mm Phillips head screws located on the processor cover.
    • Disconnect the cable.
  12. hp pavilion 15-cc023cl Motherboard Replacement: paso 12, imagen 1 de 1
    • Disconnect the plastic arm attached to the processor and remove.
    • Disconnect the cable attaching the fan to the motherboard and remove.
  13. hp pavilion 15-cc023cl Motherboard Replacement: paso 13, imagen 1 de 1
    • Use a PH1 screwdriver to unscrew one 3mm Phillips head screws on Wifi card.
    • Disconnect the Wifi card.
    • Be careful not to break any of the connectors.
  14. hp pavilion 15-cc023cl Motherboard Replacement: paso 14, imagen 1 de 3 hp pavilion 15-cc023cl Motherboard Replacement: paso 14, imagen 2 de 3 hp pavilion 15-cc023cl Motherboard Replacement: paso 14, imagen 3 de 3
    • Disconnect the 5 cables to keyboard and speakers.
    • You may have to pry some up with the spudger.
  15. hp pavilion 15-cc023cl Motherboard Replacement: paso 15, imagen 1 de 2 hp pavilion 15-cc023cl Motherboard Replacement: paso 15, imagen 2 de 2
    • Use a PH1 screwdriver to unscrew six 3 mm Phillips head screws on the motherboard.
  16. hp pavilion 15-cc023cl Motherboard Replacement: paso 16, imagen 1 de 1
    • Use the iFixit opening tools to pry motherboard from back of laptop.
  17. hp pavilion 15-cc023cl Motherboard Replacement: paso 17, imagen 1 de 1
    • Disconnect SD and USB card cable.
Conclusión
2 personas más completaron esta guía.
2 comentarios
Good job Stephany. I would’ve been lost without you…
your friend eternally,
Richey Dale
richeydale67 - Contestar
How can i get this model motherboard
Adeyinka Alasi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 1,407
