Introducción
If your Fujitsu Lifebook model a6110 laptop is overheating, or if the fan in the laptop is louder than it used to be and using compressed air didn't resolve the problem, then you will likely need to replace your fan. This guide will show you a step-by-step process on how to replace the fan in the computer.
Qué necesitas
Flip your laptop so that the bottom of the laptop is facing up and the hinges of the screen are closest to you.
Position the laptop like you would if you were to use it. Open the screen to a 180 degrees angle. The screen and the keyboard needs to face up before proceeding.
Using a flat edge of the plastic spudger, gently lift the piece of plastic located in the red square. Carefully insert the spudger between the inner edge marked by the arrow.
Lift up on the inner edges of the hinges for the screen. This will detach the face-plate from the computer. Use a spudger to make this process easier.
The ribbon is located in the top left-hand corner and needs to carefully disconnected from the motherboard, as shown in the next step.
Close the screen of the laptop, then flip the computer over so that the bottom side is facing up.
