Saltar al contenido principal
eufy RoboVac 11 Wheel and Wheel Motor Replacement
Qué necesitas
  1. eufy RoboVac 11 Wheel and Wheel Motor Replacement, Front Cover and Motherboard: paso 1, imagen 1 de 2 eufy RoboVac 11 Wheel and Wheel Motor Replacement, Front Cover and Motherboard: paso 1, imagen 2 de 2
    • Remove the nine 10 mm screws with the Phillips #1 precision screwdriver.
    • Keep track of these screws. They are the same length as the interior screws but wider in diameter.
  2. eufy RoboVac 11 Wheel and Wheel Motor Replacement: paso 2, imagen 1 de 2 eufy RoboVac 11 Wheel and Wheel Motor Replacement: paso 2, imagen 2 de 2
    • Remove the six 7 mm screws on the bumper with the Phillips #1 screwdriver.
  3. eufy RoboVac 11 Wheel and Wheel Motor Replacement: paso 3, imagen 1 de 3 eufy RoboVac 11 Wheel and Wheel Motor Replacement: paso 3, imagen 2 de 3 eufy RoboVac 11 Wheel and Wheel Motor Replacement: paso 3, imagen 3 de 3
    • Remove the top plate from the body of the device.
    • Unplug the bumper from the motherboard.
  4. eufy RoboVac 11 Wheel and Wheel Motor Replacement: paso 4, imagen 1 de 2 eufy RoboVac 11 Wheel and Wheel Motor Replacement: paso 4, imagen 2 de 2
    • Remove the three 10 mm motherboard screws with a Phillips #1 screwdriver.
    • Cleaning the motherboard and inside of the device outdoors with a compressed air cleaner will help the robot last longer.
  5. eufy RoboVac 11 Wheel and Wheel Motor Replacement: paso 5, imagen 1 de 2 eufy RoboVac 11 Wheel and Wheel Motor Replacement: paso 5, imagen 2 de 2
    • Unplug the cables from the motherboard.
  6. eufy RoboVac 11 Wheel and Wheel Motor Replacement, Rolling Brush: paso 6, imagen 1 de 2 eufy RoboVac 11 Wheel and Wheel Motor Replacement, Rolling Brush: paso 6, imagen 2 de 2
    • Remove the single 10 mm screw with the Phillips #1 screwdriver.
    • Remove the rolling brush.
  7. eufy RoboVac 11 Wheel and Wheel Motor Replacement, Wheel and Wheel Motor: paso 7, imagen 1 de 3 eufy RoboVac 11 Wheel and Wheel Motor Replacement, Wheel and Wheel Motor: paso 7, imagen 2 de 3 eufy RoboVac 11 Wheel and Wheel Motor Replacement, Wheel and Wheel Motor: paso 7, imagen 3 de 3
    • Remove the wheels.
    • The removal of the two wheels is the same on both sides, but on the left side there is a motor in the way of the wheels.
    • Remove the single 10 mm screw with the Phillips #1 screwdriver and then pull upwards to remove the piece preventing removal.
  8. eufy RoboVac 11 Wheel and Wheel Motor Replacement: paso 8, imagen 1 de 3 eufy RoboVac 11 Wheel and Wheel Motor Replacement: paso 8, imagen 2 de 3 eufy RoboVac 11 Wheel and Wheel Motor Replacement: paso 8, imagen 3 de 3
    • Remove the three 10 mm screws with the Phillips #1 screwdriver.
    • Remove motors.
    • The process for removing the left and right motors is the same.
Conclusión
Kyleigh Hill
Miembro Desde 09/27/22
223 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 66
Todo El Tiempo: 1,353
