Saltar al contenido principal
eufy RoboVac 11 Front Cover and Motherboard Replacement
Qué necesitas
  1. eufy RoboVac 11 Front Cover and Motherboard Replacement, Front Cover and Motherboard: paso 1, imagen 1 de 2 eufy RoboVac 11 Front Cover and Motherboard Replacement, Front Cover and Motherboard: paso 1, imagen 2 de 2
    • Remove the nine 10 mm screws with the Phillips #1 precision screwdriver.
    • Keep track of these screws. They are the same length as the interior screws but wider in diameter.
  2. eufy RoboVac 11 Front Cover and Motherboard Replacement: paso 2, imagen 1 de 2 eufy RoboVac 11 Front Cover and Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove the six 7 mm screws on the bumper with the Phillips #1 screwdriver.
  3. eufy RoboVac 11 Front Cover and Motherboard Replacement: paso 3, imagen 1 de 3 eufy RoboVac 11 Front Cover and Motherboard Replacement: paso 3, imagen 2 de 3 eufy RoboVac 11 Front Cover and Motherboard Replacement: paso 3, imagen 3 de 3
    • Remove the top plate from the body of the device.
    • Unplug the bumper from the motherboard.
  4. eufy RoboVac 11 Front Cover and Motherboard Replacement: paso 4, imagen 1 de 2 eufy RoboVac 11 Front Cover and Motherboard Replacement: paso 4, imagen 2 de 2
    • Remove the three 10 mm motherboard screws with a Phillips #1 screwdriver.
    • Cleaning the motherboard and inside of the device outdoors with a compressed air cleaner will help the robot last longer.
  5. eufy RoboVac 11 Front Cover and Motherboard Replacement: paso 5, imagen 1 de 2 eufy RoboVac 11 Front Cover and Motherboard Replacement: paso 5, imagen 2 de 2
    • Unplug the cables from the motherboard.
Conclusión
Una persona más ha completado esta guía.
Kyleigh Hill
Miembro Desde 09/27/22
223 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 34
Todo El Tiempo: 819
