Saltar al contenido principal
enTourage Pocket eDGe Battery Replacement
Qué necesitas
  1. enTourage Pocket eDGe Battery Replacement, Battery: paso 1, imagen 1 de 3 enTourage Pocket eDGe Battery Replacement, Battery: paso 1, imagen 2 de 3 enTourage Pocket eDGe Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Make sure the device is powered off before beginning.
    • Open the Pocket Edge and place device with the screens face down. The side containing the stylus should be on the left.
    • Remove all eight elliptical rubber tabs covering screws using your finger or spudger.
  2. enTourage Pocket eDGe Battery Replacement: paso 2, imagen 1 de 1
    • Using your J1 Phillips head screwdriver, remove all eight 6mm screws from the back of your device.
  3. enTourage Pocket eDGe Battery Replacement: paso 3, imagen 1 de 3 enTourage Pocket eDGe Battery Replacement: paso 3, imagen 2 de 3 enTourage Pocket eDGe Battery Replacement: paso 3, imagen 3 de 3
    • Using the plastic opening tool, lift the back plate from both sides of your device and remove them.
  4. enTourage Pocket eDGe Battery Replacement: paso 4, imagen 1 de 1
    • Locate the side containing the battery. Lift the top of the battery out using your finger and the indentation at the top.
  5. enTourage Pocket eDGe Battery Replacement: paso 5, imagen 1 de 1
    • Carefully unplug the bottom side of the battery from the connecting plug and set the disconnected battery aside.
Conclusión
3 personas más completaron esta guía.
Un comentario
Great tutorial! I have two of these. Does anyone know where I can buy a replacement battery? I have looked everywhere. I would retrofit if I could find one large and flat enough. 7.2v 2000mA. Hate to have to trash them but they don’t make parts anymore.
Ron - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 1,399
