Saltar al contenido principal
dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement
Qué necesitas
  1. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Prerequisite Guide to Accessing Interior: paso 1, imagen 1 de 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Prerequisite Guide to Accessing Interior: paso 1, imagen 2 de 2
    • Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
  2. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: paso 2, imagen 1 de 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: paso 2, imagen 2 de 2
    • Remove the six 2 mm PH0 screws on the bottom of the device.
    • Four of those screws are located under the foot pads.
  3. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: paso 3, imagen 1 de 1
    • Gently remove the bottom of the device.
  4. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Mother Board: paso 4, imagen 1 de 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Mother Board: paso 4, imagen 2 de 2
    • Remove the four 1.8 mm J1 screws.
    • Remove the two 2mm PH0 screws.
  5. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: paso 5, imagen 1 de 1
    • Gently pick up the mother board
    • Pick the mother board straight up or you may risk damaging the mini-USB charging ports.
  6. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: paso 6, imagen 1 de 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: paso 6, imagen 2 de 2
    • Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
  7. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Power Board: paso 7, imagen 1 de 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Power Board: paso 7, imagen 2 de 2
    • Remove the four 1.8 mm PH0 screws that are holding the board in.
    • When you remove these screws, the plastic cups inside the PS Move stations will fall out.
  8. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: paso 8, imagen 1 de 1
    • Pick up the board.
    • Pick the board straight up, or you risk damaging the charging ports.
  9. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: paso 9, imagen 1 de 1
    • Using a plastic opening tool or a similar tool, gently pry the power ribbon cord out of its port.
Conclusión
Una persona más ha completado esta guía.
Jacob
Miembro Desde 03/11/15
757 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 4
Todo El Tiempo: 200
