Saltar al contenido principal
dreamGEAR Quad Dock Pro Electrical Port Replacement
Qué necesitas
  1. dreamGEAR Quad Dock Pro Electrical Port Replacement, Prerequisite Guide to Accessing Interior: paso 1, imagen 1 de 2 dreamGEAR Quad Dock Pro Electrical Port Replacement, Prerequisite Guide to Accessing Interior: paso 1, imagen 2 de 2
    • Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
  2. dreamGEAR Quad Dock Pro Electrical Port Replacement: paso 2, imagen 1 de 2 dreamGEAR Quad Dock Pro Electrical Port Replacement: paso 2, imagen 2 de 2
    • Remove the six 2 mm PH0 screws on the bottom of the device.
    • Four of those screws are located under the foot pads.
  3. dreamGEAR Quad Dock Pro Electrical Port Replacement: paso 3, imagen 1 de 1
    • Gently remove the bottom of the device.
  4. dreamGEAR Quad Dock Pro Electrical Port Replacement, Mother Board: paso 4, imagen 1 de 2 dreamGEAR Quad Dock Pro Electrical Port Replacement, Mother Board: paso 4, imagen 2 de 2
    • Remove the four 1.8 mm J1 screws.
    • Remove the two 2mm PH0 screws.
  5. dreamGEAR Quad Dock Pro Electrical Port Replacement: paso 5, imagen 1 de 1
    • Gently pick up the mother board
    • Pick the mother board straight up or you may risk damaging the mini-USB charging ports.
  6. dreamGEAR Quad Dock Pro Electrical Port Replacement: paso 6, imagen 1 de 2 dreamGEAR Quad Dock Pro Electrical Port Replacement: paso 6, imagen 2 de 2
    • Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
  7. dreamGEAR Quad Dock Pro Electrical Port Replacement, Electrical Port: paso 7, imagen 1 de 3 dreamGEAR Quad Dock Pro Electrical Port Replacement, Electrical Port: paso 7, imagen 2 de 3 dreamGEAR Quad Dock Pro Electrical Port Replacement, Electrical Port: paso 7, imagen 3 de 3
    • Locate the three solder connections for the electrical port.
    • Desolder the connection points following the instructions included with your soldering kit as you remove the port.
    • FIRE HAZARD! BURN DANGER! Follow all the safety precautions included with your soldering kit.
    • It is helpful to use a nylon or metal spudger or tweezers for the removal of this component, pieces of which are very hot.
    • You can follow iFixit's guide to soldering here.
Conclusión
Una persona más ha completado esta guía.
Jacob
Miembro Desde 03/11/15
757 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 10
Todo El Tiempo: 308
