Saltar al contenido principal
d.light Solar Lantern S2 Solar Panel Replacement
Qué necesitas
  1. d.light Solar Lantern S2 Solar Panel Replacement, Solar Panel: paso 1, imagen 1 de 2 d.light Solar Lantern S2 Solar Panel Replacement, Solar Panel: paso 1, imagen 2 de 2
    • To remove the lens, three T15 x 12.5mm screws must be removed by a T15 head screwdriver.
    • The location of the other two screws are marked in red.
  2. d.light Solar Lantern S2 Solar Panel Replacement: paso 2, imagen 1 de 2 d.light Solar Lantern S2 Solar Panel Replacement: paso 2, imagen 2 de 2
    • After the lens has been removed the back cover needs to be removed. There are no snaps or screws holding it in place.
  3. d.light Solar Lantern S2 Solar Panel Replacement: paso 3, imagen 1 de 2 d.light Solar Lantern S2 Solar Panel Replacement: paso 3, imagen 2 de 2
    • Desolder the yellow and black wires that connect the solar panel to the circuit board.
    • Remove the solar panel by pressing on the mounting clips (underneath fingers) using the spudger.
  4. d.light Solar Lantern S2 Solar Panel Replacement: paso 4, imagen 1 de 2 d.light Solar Lantern S2 Solar Panel Replacement: paso 4, imagen 2 de 2
    • Solder the wires to the solar panel (positive to positive, negative to negative).
Conclusión
Una persona más ha completado esta guía.
Equipo
IUPUI, Team S2-G3, Harley Fall 2017 Miembro de IUPUI, Team S2-G3, Harley Fall 2017
IUPUI-HARLEY-F17S2G3
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 20
Todo El Tiempo: 645
