Saltar al contenido principal
d.light Solar Lantern S2 Circuit Board Replacement
Qué necesitas
  1. d.light Solar Lantern S2 Circuit Board Replacement, Circuit Board: paso 1, imagen 1 de 2 d.light Solar Lantern S2 Circuit Board Replacement, Circuit Board: paso 1, imagen 2 de 2
    • To remove the lens, three T15 x 12.5mm screws must be removed by a T15 head screwdriver.
    • The location of the other two screws are marked in red.
  2. d.light Solar Lantern S2 Circuit Board Replacement: paso 2, imagen 1 de 3 d.light Solar Lantern S2 Circuit Board Replacement: paso 2, imagen 2 de 3 d.light Solar Lantern S2 Circuit Board Replacement: paso 2, imagen 3 de 3
    • After the lens has been removed the back cover needs to be removed. There are no snaps or screws holding it in place.
  3. d.light Solar Lantern S2 Circuit Board Replacement: paso 3, imagen 1 de 1
    • Remove battery by unplugging it from the circuit board.
  4. d.light Solar Lantern S2 Circuit Board Replacement: paso 4, imagen 1 de 2 d.light Solar Lantern S2 Circuit Board Replacement: paso 4, imagen 2 de 2
    • Remove the circuit board by pressing on the mounting clips (shown in red circles) using the spudger.
  5. d.light Solar Lantern S2 Circuit Board Replacement: paso 5, imagen 1 de 1
    • Desolder the wires to free the circuit board.
Conclusión
2 personas más completaron esta guía.
Equipo
IUPUI, Team S2-G3, Harley Fall 2017 Miembro de IUPUI, Team S2-G3, Harley Fall 2017
IUPUI-HARLEY-F17S2G3
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 40
Todo El Tiempo: 1,206
