Saltar al contenido principal
d.light Solar Lantern S2 Battery Replacement
Qué necesitas
  1. d.light Solar Lantern S2 Battery Replacement, Battery: paso 1, imagen 1 de 2 d.light Solar Lantern S2 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • To remove the lens, three T15 x 12.5mm screws must be removed by a T15 head screwdriver.
    • The location of the other two screws are marked in red.
  2. d.light Solar Lantern S2 Battery Replacement: paso 2, imagen 1 de 3 d.light Solar Lantern S2 Battery Replacement: paso 2, imagen 2 de 3 d.light Solar Lantern S2 Battery Replacement: paso 2, imagen 3 de 3
    • After the lens has been removed the back cover needs to be removed. There are no snaps or screws holding it in place.
  3. d.light Solar Lantern S2 Battery Replacement: paso 3, imagen 1 de 3 d.light Solar Lantern S2 Battery Replacement: paso 3, imagen 2 de 3 d.light Solar Lantern S2 Battery Replacement: paso 3, imagen 3 de 3
    • Take the battery out of its setting. It is only held in by friction (no snaps or screws).
    • Disconnect the battery by unpluging the white connector.
    • Install the new battery
Conclusión
4 personas más completaron esta guía.
Equipo
IUPUI, Team S2-G3, Harley Fall 2017 Miembro de IUPUI, Team S2-G3, Harley Fall 2017
IUPUI-HARLEY-F17S2G3
3 Miembros
3 Guías creadas
Un comentario
thanks for this.
You didn’t mention the model/name of the battery replacement. Can you help with that?
Albert H - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 55
Todo El Tiempo: 2,088
