Saltar al contenido principal
Zune Flash 2nd Generation LCD Display Replacement
Qué necesitas
  1. Zune Flash 2nd Generation LCD Display Replacement, Back Cover: paso 1, imagen 1 de 2 Zune Flash 2nd Generation LCD Display Replacement, Back Cover: paso 1, imagen 2 de 2
    • Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
    • If the device turns on while it is being disassembled it could cause irreversible damage to the device.
    • PICS MAKE NO SENSE.
  2. Zune Flash 2nd Generation LCD Display Replacement: paso 2, imagen 1 de 2 Zune Flash 2nd Generation LCD Display Replacement: paso 2, imagen 2 de 2
    • Remove the top metal clip by inserting a Zune opening tool in between the faceplate and back cover and pulling gently back as shown in the images.
    • You should hear a 'click' as the clip detaches from the device.
  3. Zune Flash 2nd Generation LCD Display Replacement: paso 3, imagen 1 de 1
    • Remove the two screws shown using a Y00 Tri-Wing screwdriver.
  4. Zune Flash 2nd Generation LCD Display Replacement: paso 4, imagen 1 de 3 Zune Flash 2nd Generation LCD Display Replacement: paso 4, imagen 2 de 3 Zune Flash 2nd Generation LCD Display Replacement: paso 4, imagen 3 de 3
    • Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device.
  5. Zune Flash 2nd Generation LCD Display Replacement: paso 5, imagen 1 de 3 Zune Flash 2nd Generation LCD Display Replacement: paso 5, imagen 2 de 3 Zune Flash 2nd Generation LCD Display Replacement: paso 5, imagen 3 de 3
    • Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside.
  6. Zune Flash 2nd Generation LCD Display Replacement, Face Plate: paso 6, imagen 1 de 2 Zune Flash 2nd Generation LCD Display Replacement, Face Plate: paso 6, imagen 2 de 2
    • Remove the three screws (5.5mm by 3mm) from the backside of the Zune using a Y00 Tri-Wing screwdriver.
    • Be sure to put this set of screws aside since they are a different size than any other screws in the device.
  7. Zune Flash 2nd Generation LCD Display Replacement: paso 7, imagen 1 de 2 Zune Flash 2nd Generation LCD Display Replacement: paso 7, imagen 2 de 2
    • Use your finger or a Zune opening tool to pry back the two clear flaps.
    • Next lift the communications board that was being held down by the clear flaps.
    • Be careful not to accidentally detach the slim ribbon that connects between the communications board and the device.
  8. Zune Flash 2nd Generation LCD Display Replacement: paso 8, imagen 1 de 3 Zune Flash 2nd Generation LCD Display Replacement: paso 8, imagen 2 de 3 Zune Flash 2nd Generation LCD Display Replacement: paso 8, imagen 3 de 3
    • Disconnect the ribbon with the plastic opening tool by flipping up the black plastic flap where the ribbon connects to the memory board.
    • Carefully pull the ribbon out of the memory board, ensuring that the black plastic flap is up before removal to avoid the ripping the ribbon.
  9. Zune Flash 2nd Generation LCD Display Replacement: paso 9, imagen 1 de 3 Zune Flash 2nd Generation LCD Display Replacement: paso 9, imagen 2 de 3 Zune Flash 2nd Generation LCD Display Replacement: paso 9, imagen 3 de 3
    • Remove the battery by prying the battery off from the bottom with a Zune opening tool.
    • There is an adhesive between the battery and the device, therefore use a metal spudger to finish detaching the battery.
    • Be sure not to puncture the battery in any way when using the metal spudger.
  10. Zune Flash 2nd Generation LCD Display Replacement: paso 10, imagen 1 de 2 Zune Flash 2nd Generation LCD Display Replacement: paso 10, imagen 2 de 2
    • Remove the single screw under the battery using a small Tri-Wing screwdriver.
  11. Zune Flash 2nd Generation LCD Display Replacement: paso 11, imagen 1 de 1
    • Disconnect the faceplate from the device by depressing the two tabs located near the middle of each of the sides using a metal spudger.
    • This will disconnect the last circuit board in the device from the center frame.
  12. Zune Flash 2nd Generation LCD Display Replacement: paso 12, imagen 1 de 3 Zune Flash 2nd Generation LCD Display Replacement: paso 12, imagen 2 de 3 Zune Flash 2nd Generation LCD Display Replacement: paso 12, imagen 3 de 3
    • Remove the faceplate by using a metal spudger to separate it from the remaining components.
  13. Zune Flash 2nd Generation LCD Display Replacement, LCD Display: paso 13, imagen 1 de 1
    • Release the LCD connector ribbon by flipping up the black switch. This will disconnect the LCD from the device.
    • At this point the LCD screen should be easily separable from the device.
  14. Zune Flash 2nd Generation LCD Display Replacement: paso 14, imagen 1 de 3 Zune Flash 2nd Generation LCD Display Replacement: paso 14, imagen 2 de 3 Zune Flash 2nd Generation LCD Display Replacement: paso 14, imagen 3 de 3
    • The LCD ribbon is adhered to the memory board with a strip of glue.
    • It's safest to flip the display over before removing the ribbon, as shown in the first image.
    • To avoid damage, remove the LCD by pulling slowly and carefully on the ribbon, directly away from the memory board.
Conclusión
ybahman
Miembro Desde 11/01/09
139 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 9-20, Regan Fall 2009 Miembro de Cal Poly, Team 9-20, Regan Fall 2009
CPSU-REGAN-F09S9G20
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 13
Todo El Tiempo: 4,458
