Saltar al contenido principal
Zune Flash 2nd Generation Back Cover Replacement
Qué necesitas
  1. Zune Flash 2nd Generation Back Cover Replacement, Back Cover: paso 1, imagen 1 de 2 Zune Flash 2nd Generation Back Cover Replacement, Back Cover: paso 1, imagen 2 de 2
    • Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
    • If the device turns on while it is being disassembled it could cause irreversible damage to the device.
    • PICS MAKE NO SENSE.
  2. Zune Flash 2nd Generation Back Cover Replacement: paso 2, imagen 1 de 2 Zune Flash 2nd Generation Back Cover Replacement: paso 2, imagen 2 de 2
    • Remove the top metal clip by inserting a Zune opening tool in between the faceplate and back cover and pulling gently back as shown in the images.
    • You should hear a 'click' as the clip detaches from the device.
  3. Zune Flash 2nd Generation Back Cover Replacement: paso 3, imagen 1 de 1
    • Remove the two screws shown using a Y00 Tri-Wing screwdriver.
  4. Zune Flash 2nd Generation Back Cover Replacement: paso 4, imagen 1 de 3 Zune Flash 2nd Generation Back Cover Replacement: paso 4, imagen 2 de 3 Zune Flash 2nd Generation Back Cover Replacement: paso 4, imagen 3 de 3
    • Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device.
  5. Zune Flash 2nd Generation Back Cover Replacement: paso 5, imagen 1 de 3 Zune Flash 2nd Generation Back Cover Replacement: paso 5, imagen 2 de 3 Zune Flash 2nd Generation Back Cover Replacement: paso 5, imagen 3 de 3
    • Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside.
Conclusión
ybahman
Miembro Desde 11/01/09
139 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 9-20, Regan Fall 2009 Miembro de Cal Poly, Team 9-20, Regan Fall 2009
CPSU-REGAN-F09S9G20
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 3,683
