Saltar al contenido principal
Zte Avail 2 Display Replacement
Qué necesitas
  1. Zte Avail 2 Display Replacement, Battery: paso 1, imagen 1 de 3 Zte Avail 2 Display Replacement, Battery: paso 1, imagen 2 de 3 Zte Avail 2 Display Replacement, Battery: paso 1, imagen 3 de 3
    • Before disassembling your ZTE Avail 2, be sure it is powered off.
    • Remove the back cover using the notch at the bottom of the device.
    • Pull the back cover from the front panel gently to remove it.
  2. Zte Avail 2 Display Replacement: paso 2, imagen 1 de 2 Zte Avail 2 Display Replacement: paso 2, imagen 2 de 2
    • Remove the battery by the notch in the back plate.
  3. Zte Avail 2 Display Replacement, Display: paso 3, imagen 1 de 1
    • Using your J00 screwdriver, unscrew each of the 8 Philips head 1.19mm screws from the black plate of the device.
  4. Zte Avail 2 Display Replacement: paso 4, imagen 1 de 2 Zte Avail 2 Display Replacement: paso 4, imagen 2 de 2
    • Using a spudger or plastic opening tool, pull up from underneath the back plate and pop off the piece.
  5. Zte Avail 2 Display Replacement: paso 5, imagen 1 de 2 Zte Avail 2 Display Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using the tweezers remove the 4 orange ribbon cables. Do this by lifting their corresponding black connectors and pulling the ribbon out.
  6. Zte Avail 2 Display Replacement: paso 6, imagen 1 de 1
    • On the left side you will see a cellular antenna cable wire. Remove this wire by gently pulling it off.
  7. Zte Avail 2 Display Replacement: paso 7, imagen 1 de 1
    • Lift and set aside the motherboard from lying on top of the silver plate (this may require some force because it is held on by adhesive).
  8. Zte Avail 2 Display Replacement: paso 8, imagen 1 de 1
    • Using an opening tool, lift and remove the silver metal plate off the back of the device (use some force here).
  9. Zte Avail 2 Display Replacement: paso 9, imagen 1 de 1
    • Pry open to separate the metal piece from the front screen attachment using a plastic spudger.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
Conclusión
5 personas más completaron esta guía.
Un comentario
My screen is completely white and I DON'T have to turn the power off, jus the screen off n on n still screen is white. I can't hardly see my apps. Plz tell me what's wrong with my phone. I was thinking somewhere along the lines of my LED cuz everything looks kind of like a negative photo.
Joyce - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 983
