Saltar al contenido principal
Zotac GTX 1080 Ti Mini Fans Replacement
Qué necesitas
  1. Zotac GTX 1080 Ti Mini Fans Replacement, Zotac GTX 1080 Ti Mini Fans: paso 1, imagen 1 de 2 Zotac GTX 1080 Ti Mini Fans Replacement, Zotac GTX 1080 Ti Mini Fans: paso 1, imagen 2 de 2
    • Be sure to properly ground yourself with an anti-static wristband before working on the graphics card.
    • Use a Phillips #0 screwdriver to remove the two 4mm screws from the right side of the shroud.
  2. Zotac GTX 1080 Ti Mini Fans Replacement: paso 2, imagen 1 de 2 Zotac GTX 1080 Ti Mini Fans Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the two 4mm screws from the left side of the shroud.
  3. Zotac GTX 1080 Ti Mini Fans Replacement: paso 3, imagen 1 de 2 Zotac GTX 1080 Ti Mini Fans Replacement: paso 3, imagen 2 de 2
    • Look for the fan header located beside the 16-pin power connector.
    • Gently pry the fan connector apart from the header with a flathead screwdriver.
  4. Zotac GTX 1080 Ti Mini Fans Replacement: paso 4, imagen 1 de 2 Zotac GTX 1080 Ti Mini Fans Replacement: paso 4, imagen 2 de 2
    • Slowly and carefully lift the shroud off the heatsink.
    • During this step, make sure not to damage the LED connector that is still connecting the shroud to the PCB.
    • Flip the shroud along the top of the graphics card.
  5. Zotac GTX 1080 Ti Mini Fans Replacement: paso 5, imagen 1 de 3 Zotac GTX 1080 Ti Mini Fans Replacement: paso 5, imagen 2 de 3 Zotac GTX 1080 Ti Mini Fans Replacement: paso 5, imagen 3 de 3
    • Remove the three 3 mm Phillips screws holding the fans to the heatsink with a Phillips #0 screwdriver.
    • Remove the broken fans.
  6. Zotac GTX 1080 Ti Mini Fans Replacement: paso 6, imagen 1 de 3 Zotac GTX 1080 Ti Mini Fans Replacement: paso 6, imagen 2 de 3 Zotac GTX 1080 Ti Mini Fans Replacement: paso 6, imagen 3 de 3
    • Place the replacement fan on top of the heatsink with the screw holes aligned.
    • Screw the fans into place using a Phillips #0 screwdriver.
  7. Zotac GTX 1080 Ti Mini Fans Replacement: paso 7, imagen 1 de 1
    • Reconnect the fan connector to its header.
  8. Zotac GTX 1080 Ti Mini Fans Replacement: paso 8, imagen 1 de 3 Zotac GTX 1080 Ti Mini Fans Replacement: paso 8, imagen 2 de 3 Zotac GTX 1080 Ti Mini Fans Replacement: paso 8, imagen 3 de 3
    • Place the shroud back over the heatsink and screw it back into place using a Phillips #0 screwdriver.
Conclusión
Hopefully, your graphics card is fully replaced and completely working now.
Una persona más ha completado esta guía.
Victor Pan
Miembro Desde 01/27/21
175 Reputación
1 Guía escrita
Equipo
Un comentario
Do you know what size (diameter and thread) the 4mm and 3mm screws are?
cchagadorn - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 21
Ultimos 30 días: 67
Todo El Tiempo: 4,726
