Introducción
Zotac's bare-bones machines come without Internal Storage or RAM. Here's how to install the Internal Storage.
Qué necesitas
Zotac uses thumb screws to secure the case. No tools required!
After you remove the thumb screws, just slide the bottom cover away from you and lift it away.
The EN970 has three hard drive connectors: 2 2.5" bays and 1 M.2 bay.
There are thumb screws for the 2.5" drives that secure plastic caddies that snap onto your drive
The M.2 drive requires a phillips screwdriver for installation. Your ZBOX should have two screws inserted in two of the three pegs.
Remove the screws, insert your drive and use one screw to secure it. Be sure not to over-tighten.
9 personas más completaron esta guía.
