Introducción
The chest sensor is needed for many of the device's functions, making it one of the device's most important features. This guide will go over the steps to remove and replace the sensor in case it becomes damaged.
  1. Using the Triangle driver remove the four 7.5 mm screws. The two front screws are deeper than the two on the back legs which may cause difficulties. These can be reached by putting the bit in first then carefully putting the driver on slightly (not all the way) The two front screws are deeper than the two on the back legs which may cause difficulties. These can be reached by putting the bit in first then carefully putting the driver on slightly (not all the way)
    • Using the Triangle driver remove the four 7.5 mm screws.
    • The two front screws are deeper than the two on the back legs which may cause difficulties. These can be reached by putting the bit in first then carefully putting the driver on slightly (not all the way)
  2. Turn the device so that the the device is on its side. Hold the back and belly on the device and gently pull apart.
    • Turn the device so that the the device is on its side.
    • Hold the back and belly on the device and gently pull apart.
    • Pulling with too much force might damage a few cables inside, so caution is needed.
  3. With insides exposed, grab leg and gently pull up and away from the body to detach them. Repeat for all legs needed. With insides exposed, grab leg and gently pull up and away from the body to detach them. Repeat for all legs needed. With insides exposed, grab leg and gently pull up and away from the body to detach them. Repeat for all legs needed.
    • With insides exposed, grab leg and gently pull up and away from the body to detach them. Repeat for all legs needed.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Carefully pry the ribbon cable from the connector. Though we find it easier to use our fingers, the pry-tools may be useful. Though we find it easier to use our fingers, the pry-tools may be useful.
    • Carefully pry the ribbon cable from the connector.
    • Though we find it easier to use our fingers, the pry-tools may be useful.
  6. For easier access to the sensor, tilt and pull the sensor away from the body. For easier access to the sensor, tilt and pull the sensor away from the body. For easier access to the sensor, tilt and pull the sensor away from the body.
    • For easier access to the sensor, tilt and pull the sensor away from the body.
  7. To remove the sensors, use a soldering iron to solder the  two points and remove the  red and black wires from the reverse side. The soldering iron is very hot, so take caution not to touch it directly in order to avoid burns. The soldering iron is very hot, so take caution not to touch it directly in order to avoid burns.
    • To remove the sensors, use a soldering iron to solder the two points and remove the red and black wires from the reverse side.
    • The soldering iron is very hot, so take caution not to touch it directly in order to avoid burns.
  8. Turn the sensors over and locate the solder points of the remaining white wires. Heat the solder and remove the pair of  wires. The sensor should be completely detachable now.
    • Turn the sensors over and locate the solder points of the remaining white wires. Heat the solder and remove the pair of wires.
    • The sensor should be completely detachable now.
Conclusión
Mitchell Gentry
Miembro Desde 14/02/18
651 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S6-G2, Eyestone Spring 2018 Miembro de USF Tampa, Team S6-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S6G2
3 Miembros
8 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 5
Últimos 30 Días: 26
Todo El Tiempo: 119
