Saltar al contenido principal
Zoombak Personal GPS Locator Battery Replacement
Qué necesitas
  1. Zoombak Personal GPS Locator Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Zoombak Personal GPS device
  2. Zoombak Personal GPS Locator Battery Replacement: paso 2, imagen 1 de 1
    • Backside has four rubber plugs. Remove them and find the Phillips head screws.
  3. Zoombak Personal GPS Locator Battery Replacement: paso 3, imagen 1 de 1
    • Use a small tip flat blade screw driver to remove the rubber plugs.
  4. Zoombak Personal GPS Locator Battery Replacement: paso 4, imagen 1 de 1
    • Plugs removed
  5. Zoombak Personal GPS Locator Battery Replacement: paso 5, imagen 1 de 1
    • Rubber plugs
  6. Zoombak Personal GPS Locator Battery Replacement: paso 6, imagen 1 de 1
    • Remove the bottom cover.
  7. Zoombak Personal GPS Locator Battery Replacement: paso 7, imagen 1 de 1
    • Old battery. No numbers just 3.7 volt 890mAh. Very difficult to figure out. I found a Sony Erricson J100, J220, W710, W810, Z300, Z710 battery that fits perfectly.
  8. Zoombak Personal GPS Locator Battery Replacement: paso 8, imagen 1 de 1
    • The old one was swollen from being on the charger for so long.
  9. Zoombak Personal GPS Locator Battery Replacement: paso 9, imagen 1 de 1
    • The case without the battery.
  10. Zoombak Personal GPS Locator Battery Replacement: paso 10, imagen 1 de 1
    • New battery installed.
  11. Zoombak Personal GPS Locator Battery Replacement: paso 11, imagen 1 de 1
    • And turn it back on, and it blinks green! I let it run down and recharged the battery. I get about 3 days use from it now. Good luck!
Conclusión
3 personas más completaron esta guía.
James
Miembro Desde 10/04/10
113 Reputación
1 Guía escrita
2 comentarios
Excellent guide! Precise step-by-step instructions. The recommended replacement battery was a perfect fit, and works like the original battery. Took about 20 minutes and approx $5.00 for the new battery to do the entire job.
I wish all how-to guides were as well written and easy to follow as this one. Thanks!
j fkmetz - Contestar
Zoombak.com is gone. How do I reactivate mine, and get the software that did the tracking back.
Sean Connors - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 4,247
