Introducción
The Zoombak's battery life weakens over time and it needs to be replace. It will no longer hold a charge. Instead of shipping it back to the company and paying to have the battery replaced, you can do it yourself if you have the right tools and the right battery. Finding the right battery was the most challenging part.
I found a Sony Erricson J100, J220, W710, W810, Z300, Z710 battery that fits perfectly.
  1. Zoombak Personal GPS device
    • Zoombak Personal GPS device
  2. Backside has four rubber plugs.  Remove them and find the Phillips head screws.
    • Backside has four rubber plugs. Remove them and find the Phillips head screws.
  3. Use a small tip flat blade screw driver to remove the rubber plugs.
    • Use a small tip flat blade screw driver to remove the rubber plugs.
  4. Plugs removed
    • Plugs removed
  5. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  6. Rubber plugs
    • Rubber plugs
  7. Remove the bottom cover.
    • Remove the bottom cover.
  8. Old battery.  No numbers just 3.7 volt 890mAh.  Very difficult to figure out.  I found a Sony Erricson J100, J220, W710, W810, Z300, Z710 battery that fits perfectly.
    • Old battery. No numbers just 3.7 volt 890mAh. Very difficult to figure out. I found a Sony Erricson J100, J220, W710, W810, Z300, Z710 battery that fits perfectly.
  9. The old one was swollen from being on the charger for so long.
    • The old one was swollen from being on the charger for so long.
  10. The case without the battery.
    • The case without the battery.
  11. New battery installed.
    • New battery installed.
  12. And turn it back on, and it blinks green!  I let it run down and recharged the battery.  I get about 3 days use from it now.  Good luck!
    • And turn it back on, and it blinks green! I let it run down and recharged the battery. I get about 3 days use from it now. Good luck!
Conclusión
3 personas más completaron esta guía.
James
Miembro Desde 04/10/10
113 Reputación
1 Guía escrita
Excellent guide! Precise step-by-step instructions. The recommended replacement battery was a perfect fit, and works like the original battery. Took about 20 minutes and approx $5.00 for the new battery to do the entire job.
I wish all how-to guides were as well written and easy to follow as this one. Thanks!
j fkmetz - Contestar
Zoombak.com is gone. How do I reactivate mine, and get the software that did the tracking back.
Sean Connors - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 3,956
