Introducción
The mic connector will need to be replaced when the audio doesn't get picked up or when the mic connector breaks, preventing the mic components from attaching to the device. In order to replace the mic connector, several steps will need to be performed.
Qué necesitas
Place device face up and pry off the four knobs using the flat end of the plastic opening tool.
Unscrew three (PH #1), 7mm screws from the display backing and gently flip over.
Gently remove three ribbon connectors from the device.
The first is connected to the mic connector.
The second is connected to the base of the device, and the third is connected to the power switch on the side of the device; turn the device 180 degrees, and the connectors are near the top of the device next to the "LINE OUT" plug-in (directly behind the device display).
Lift the mic connector from the base of the device and replace with a new component.
Una persona más ha completado esta guía.
