Saltar al contenido principal
Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
Qué necesitas
  1. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement, SPM Vent Kit: paso 1, imagen 1 de 1
    • Loosen but do not remove the(4) 8-32 X 3 screws on the outer air intake.
  2. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 2, imagen 1 de 2 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 2, imagen 2 de 2
    • Loosen and remove the (2) 10-32 Keps nuts and the (4) 6-32 X 2 screws. Remove the back case by lifting from the ventilator.
  3. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 3, imagen 1 de 2 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 3, imagen 2 de 2
    • Remove the (2) 4-40 X ¼ screws on the Dovetail Mounting Bracket and disconnect the ribbon cable on the PIM PCB by simultaneously applying pressure on the two locking “ears”.
  4. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 4, imagen 1 de 1
    • Flip the ventilator over and remove the front case assembly by lifting it straight up away from the ventilator module.
  5. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 5, imagen 1 de 3 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 5, imagen 2 de 3 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 5, imagen 3 de 3
    • Remove the battery compartment cover by unscrewing the (4) 6-32 X 5/16 screws.
  6. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 6, imagen 1 de 1
    • Remove the battery by unscrewing the (4) 6-32 X 2 ¼ screws and detaching the plug from its lockinglatch.
  7. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 7, imagen 1 de 1
    • Unscrew the (4) 6-32 X 5/16 Phillips screws to remove the damaged battery compartment case.
  8. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 8, imagen 1 de 1
    • Loosen and remove the (2) 4-40 X 1 ¼ Screws and nylon spacers supporting the Power Input assembly unto the chassis
  9. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 9, imagen 1 de 1
    • Loosen and remove the (2) 6-32 X ¼ screws holding the chassis to the dovetail mounting bracket and remove the SPO2 insulator. Loosen and remove the (2) 8-32 X ¼ screws holding the chassis to the vent module
  10. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 10, imagen 1 de 1
    • Insert screwdriver through the holes on the chassis to loosen and remove the (2) 6-32 x 5/16 screws holding the chassis to the vent module.
  11. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 11, imagen 1 de 1
    • Lift the damaged chassis from the ventilator module.
  12. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 12, imagen 1 de 1
    • Disconnect the Power Input cable from the PIM PCB by pressing on the locking latch and pulling the cable straight up from the connector.
  13. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 13, imagen 1 de 1
    • Remove the PIM PCB by loosening the (5) 4-40 X 5/16 screws.
  14. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 14, imagen 1 de 1
    • Remove the Dovetail stabilizer bracket by loosening and removing the (2) 6-32 x ¼ and the (2) 4-40 X ¼ screws.
  15. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 15, imagen 1 de 1
    • Install the dovetail stabilizer bracket ontothe new SPM assembly by tightening the (2) 6-32 X ¼ and (2) 4-40 X ¼ screws.
  16. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 16, imagen 1 de 1
    • Secure the PIM Board to the new SPM with the (5) 4-40 x 5/16 screws.
  17. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 17, imagen 1 de 1
    • Secure the chassis to the vent module using the (2) 6-32 X ¼ screws with SPO2 insulator, the (2) 8-32 X ¼ and the (2) 6-32 x 5/16 screws.
  18. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 18, imagen 1 de 1
    • Secure the Power Input assembly to the Chassis using the (2) spacers and (2) 4-40 X 1 ¼ screws. Do not over-tighten the screws.
  19. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 19, imagen 1 de 2 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 19, imagen 2 de 2
    • Rotate battery compartment to mate with upper and lower case cutouts and press firmly into place. Secure with (4) 6-32 X 5/16 screws provided
  20. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 20, imagen 1 de 1
    • Re-assemble the battery by connecting its cable to the connector (pull on cable to insure it is locked in place) then tightening the (4) 6-32 X 2 ¼ screws.
  21. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 21, imagen 1 de 3 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 21, imagen 2 de 3 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 21, imagen 3 de 3
    • Re-assemble the battery compartment cover by tightening the (4) 6-32 X 5/16 screws.
  22. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 22, imagen 1 de 1
    • Place the front case assembly over the vent module and tighten the (2) 4-40 X ¼ screws unto the dovetail mounting bracket. Reconnect the ribbon cable unto the PIM PCB. Make sure the two locking “ears” lock into position.
  23. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 23, imagen 1 de 1
    • Attach the back case to the vent module and align cover with handle, air intake housing and dovetail mounting studs. Insert and tighten the included (2) 10-32 Keps nuts and the (4) 6-32 X 2” screws.
  24. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 24, imagen 1 de 2 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 24, imagen 2 de 2
    • Tighten the (4) 8-32 X 3 screws on the outer air intake.
  25. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: paso 25, imagen 1 de 1
    • Perform HiPot Testing then perform Calibration and Functional Test using the RCS.
Conclusión
Una persona más ha completado esta guía.
Brandon Drury
Miembro Desde 05/04/20
391 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S1-G5, Zimmerman Spring 2020 Miembro de Cal Poly, Team S1-G5, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G5
5 Miembros
5 Guías creadas
Un comentario
Hi
What is the service passcode to reset the PM clock?
fayezhmc - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 274
