Saltar al contenido principal
Zoll Impact Uni-Vent 731 Battery Compartment Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
Qué necesitas
  1. Zoll Impact Uni-Vent 731 Battery Compartment Replacement, Battery Compartment Kit: paso 1, imagen 1 de 1
    • Remove the battery compartment cover by unscrewing the (4) Phillips 6-32 X 5/16 screws. This is indicated in red with the number 1.
    • Page 25.
  2. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: paso 2, imagen 1 de 2 Zoll Impact Uni-Vent 731 Battery Compartment Replacement: paso 2, imagen 2 de 2
    • Remove the battery by unscrewing the (4)Phillips 6-32 X 2 ¼ screws and detaching the plug from its locking latch. This is indicated in the second picture in blue with the number 2.
    • Page 25.
  3. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: paso 3, imagen 1 de 1
    • Unscrew the (4) 6-32 X 5/16 Phillips screws to remove the damaged battery compartment case.
    • Page 25.
  4. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: paso 4, imagen 1 de 1
    • Rotate battery compartment to mate with upper and lower case cutouts and press firmly into place. Secure with (4) Phillips 6-32 X 5/16 screws provided.
    • Page 25.
  5. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: paso 5, imagen 1 de 1
    • Re-assemble the battery by connecting its cable to the connector (pull on cable to insure it is locked in place) then tightening the (4) Phillips 6-32 X 2 ¼ screws. This is indicated in blue with the number 5.
    • Page 25.
  6. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: paso 6, imagen 1 de 1
    • Re-assemble the battery compartment cover by tightening the (4) 6-32 X5/16 screws. This is indicated in red with the number 6.
    • Page 25.
  7. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: paso 7, imagen 1 de 1
    • Perform HiPot Testing then perform Functional Test using the RCS to verify the replacement is working properly.
    • Page 25.
Conclusión
Michaela Fromm
Miembro Desde 05/04/20
150 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S1-G5, Zimmerman Spring 2020 Miembro de Cal Poly, Team S1-G5, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G5
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 218
