Introducción
In the process of disconnecting the motherboard you will begin with taking off 4 screws with a phillips screwdriver. Once that is done you should be careful with disconnecting all the cables connected to the board, making sure you don't tear any of the wires.
Qué necesitas
Peel back the touch interface chip (which is on the top right of the motherboard, covered in yellow tape.)
2 personas más completaron esta guía.
