Saltar al contenido principal
Zenithink ZTPAD ZT280 C91 Camera Replacement
Qué necesitas
  1. Zenithink ZTPAD ZT280 C91 Camera Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove the two screws on the bottom using a Phillips #00 screwdriver.
    • For differentiation purposes, these screws are 4mm long.
  2. Zenithink ZTPAD ZT280 C91 Camera Replacement: paso 2, imagen 1 de 3 Zenithink ZTPAD ZT280 C91 Camera Replacement: paso 2, imagen 2 de 3 Zenithink ZTPAD ZT280 C91 Camera Replacement: paso 2, imagen 3 de 3
    • Using a spudger, start prying the case apart by working around the edge slowly.
    • Be careful not to damage any of the latches that hold the back panel in place, especially if you are using a metal spudger.
    • While prying, be careful to not lose the power and volume buttons; the case is the only thing holding them in place so they will easily come out once the panel has been removed
    • Be careful to not damage the speaker cables, they will still be connecting both panels.
  3. Zenithink ZTPAD ZT280 C91 Camera Replacement, Motherboard: paso 3, imagen 1 de 1
    • Peel back the touch interface chip (which is on the top right of the motherboard, covered in yellow tape.)
  4. Zenithink ZTPAD ZT280 C91 Camera Replacement: paso 4, imagen 1 de 1
    • Flip up the small gate and unplug the ribbon cable shown.
  5. Zenithink ZTPAD ZT280 C91 Camera Replacement: paso 5, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the screws highlighted with the orange rings as shown in the picture.
    • For differentiation purposes, these screws are 3.5mm long.
  6. Zenithink ZTPAD ZT280 C91 Camera Replacement: paso 6, imagen 1 de 1
    • Slide back the plastic latch for the main display cable.
    • Carefully unplug the cable with tweezers.
  7. Zenithink ZTPAD ZT280 C91 Camera Replacement: paso 7, imagen 1 de 2 Zenithink ZTPAD ZT280 C91 Camera Replacement: paso 7, imagen 2 de 2
    • Slide back the plastic latch for the camera cable.
  8. Zenithink ZTPAD ZT280 C91 Camera Replacement: paso 8, imagen 1 de 1
    • Peel back the reflective tape.
  9. Zenithink ZTPAD ZT280 C91 Camera Replacement: paso 9, imagen 1 de 2 Zenithink ZTPAD ZT280 C91 Camera Replacement: paso 9, imagen 2 de 2
    • Lift up the motherboard assembly, starting by lifting up the top.
    • Be careful not to damage any of the ports on the underside of the tablet.
    • The camera cable will slide through a small notch and end up underneath the board.
  10. Zenithink ZTPAD ZT280 C91 Camera Replacement, Camera: paso 10, imagen 1 de 1
    • Peel back the adhesive tape holding the camera in place.
    • Remove the camera from the device.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 130
