Saltar al contenido principal
Zenbre SoundBank Z3 Speaker Replacement
Qué necesitas
  1. Zenbre SoundBank Z3 Speaker Replacement, Bottom Cover: paso 1, imagen 1 de 2 Zenbre SoundBank Z3 Speaker Replacement, Bottom Cover: paso 1, imagen 2 de 2
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Zenbre SoundBank Z3 Speaker Replacement: paso 2, imagen 1 de 1
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Zenbre SoundBank Z3 Speaker Replacement: paso 3, imagen 1 de 2 Zenbre SoundBank Z3 Speaker Replacement: paso 3, imagen 2 de 2
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: paso 4, imagen 1 de 3 Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: paso 4, imagen 2 de 3 Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: paso 4, imagen 3 de 3
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Zenbre SoundBank Z3 Speaker Replacement, Speakers: paso 5, imagen 1 de 2 Zenbre SoundBank Z3 Speaker Replacement, Speakers: paso 5, imagen 2 de 2
    • Remove the three screws that are holding the speaker down.
    • Be careful not to rip out the speaker while taking out the screws.
  6. Zenbre SoundBank Z3 Speaker Replacement: paso 6, imagen 1 de 2 Zenbre SoundBank Z3 Speaker Replacement: paso 6, imagen 2 de 2
    • Desolder the speaker joints from the motherboard. Follow this How To Solder guide for help with desoldering.
  7. Zenbre SoundBank Z3 Speaker Replacement: paso 7, imagen 1 de 2 Zenbre SoundBank Z3 Speaker Replacement: paso 7, imagen 2 de 2
    • Remove the speaker from the motherboard.
    • Remove the speaker ring.
    • Be careful not to remove other components in the speaker.
    • Repeat Steps 5-7 with the other speaker.
Conclusión
Una persona más ha completado esta guía.
Cherian Thomas
Miembro Desde 03/25/16
334 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 463
