Saltar al contenido principal
Zeki TBQG884B Camera Replacement
Qué necesitas
  1. Zeki TBQG884B Camera Replacement, Rear Case: paso 1, imagen 1 de 2 Zeki TBQG884B Camera Replacement, Rear Case: paso 1, imagen 2 de 2
    • Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
  2. Zeki TBQG884B Camera Replacement: paso 2, imagen 1 de 1
    • Place the tablet down so that the screen is facing away from you.
    • Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
    • Gently work your way around the perimeter of the tablet's edge.
  3. Zeki TBQG884B Camera Replacement: paso 3, imagen 1 de 2 Zeki TBQG884B Camera Replacement: paso 3, imagen 2 de 2
    • Remove the back cover
    • Remove any tape on the speaker and detach the speaker from the back plate.
    • The speaker is connected to the motherboard by two soldered wires. Don't break them when you remove the speaker.
  4. Zeki TBQG884B Camera Replacement, Camera: paso 4, imagen 1 de 2 Zeki TBQG884B Camera Replacement, Camera: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Open the ZIF connector, the black lock part over the wire ribbon in the motherboard, and remove the wire ribbon that connects the motherboard and the camera.
    • The camera is located on the top left, above the motherboard.
    • The camera is usually covered with tape or material. Peel material/tape off with tweezers for safety.
Conclusión
2 personas más completaron esta guía.
Natalie Holm
Miembro Desde 09/16/15
137 Reputación
1 Guía escrita
Equipo
IUPUI, Team 1-3, Harley Fall 2015 Miembro de IUPUI, Team 1-3, Harley Fall 2015
IUPUI-HARLEY-F15S1G3
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 288
