Introducción
If for any reason your device has been dropped, damaged, or cracked, then it could interfere with the sensitivity of the screen. If this happens to be the case, then here's a solution to replace a damaged display.
Qué necesitas
Using the plastic spudger, remove the back casing of the device (it will snap off).
Casi Terminas!
Conclusión
