Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Zeki Droid Tablet Camera Replacement
Qué necesitas
  1. Zeki Droid Tablet Camera Replacement, Back Casing: paso 1, imagen 1 de 1
    • Remove the back casing by slowly popping each tab out with a plastic opening tool.
    Pregunta a FixBot
  2. Zeki Droid Tablet Camera Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Remove the tapes one by one from the connecting wires with tweezers.
    Pregunta a FixBot
  3. Zeki Droid Tablet Camera Replacement: paso 3, imagen 1 de 1
    • Remove the black clips from both sides of the casing with a plastic opening tool.
    • The clips should pop off separate from the speakers.
    Pregunta a FixBot
  4. Zeki Droid Tablet Camera Replacement: paso 4, imagen 1 de 1
    • Remove the speakers from the back casing.
    • Do not tug on the speakers because they are connected to fragile wires.
    Pregunta a FixBot
  5. Zeki Droid Tablet Camera Replacement: paso 5, imagen 1 de 1
    • Pull the speakers away from the back casing carefullly.
    Pregunta a FixBot
  6. Zeki Droid Tablet Camera Replacement, Camera: paso 6, imagen 1 de 2 Zeki Droid Tablet Camera Replacement, Camera: paso 6, imagen 2 de 2
    • Grip the camera on both sides using tweezers or your fingers, and carefully lift it off the board.
    • The adhesive may make it difficult to remove the cameras from the tablet.
    Pregunta a FixBot
  7. Zeki Droid Tablet Camera Replacement: paso 7, imagen 1 de 1
    • Undo the ZIF connector that is connecting the cameras to the motherboard using a plastic spudger or fingernail.
    • This guide has more information on how to undo the ZIF connector
    • Do not yank the ZIF connector. It should come apart very easily with little force needed.
    Pregunta a FixBot
  8. Zeki Droid Tablet Camera Replacement: paso 8, imagen 1 de 1
    • Pull the copper connection carefully away from the motherboard of the tablet to completely remove the camera.
    Pregunta a FixBot
Conclusión
Una persona más ha completado esta guía.
Equipo
Colorado Springs, Team 2-6, Panko Spring 2015 Miembro de Colorado Springs, Team 2-6, Panko Spring 2015
UCCS-PANKO-S15S2G6
Miembros de 3
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 41
Todo El Tiempo: 577
